Board repair on Aquastat L8148E
mwbsmith
Member Posts: 3
My Buderus furnace shut down and I found that jiggling the damper plug would get it to come back on. From other people's comments in various places, I determined that the solder on the board must be cracked.
I pulled the board and it was indeed cracked. I carefully put little droplets of fresh solder around the five pins behind the damper plug, put everything back together and it fired up without issue. However, there is a piece of cardboard that was on the back of the board that I just found, that I forgot to put back in place. Is that particularly important or just to keep dust out?
Is that a safe fix (can't see why it's not) or is a new board in order?
Thanks!
Thanks!
Not safe...manufacture states no altering of product....anything can happen....buy another aquastat relay not that expensiveASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
The cardboard in the back is there to protect the backside of board from shorting out against the metal. Put the cardboard back in.Qasim mohmood
Asm mechanical Company
152 watchogue rd
staten island ny 10314
Asmmechanicalcorp@gmail.com
Asmhvacnyc.com
347-692-47770 -
Paul S.: Any recommendation for a vendor?0
Online try supplyhouse.com....where u locatedASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
NC0
I dont know vendors out there but any plumbing supply should stock that control...at least up here they doASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
