hot water circulation
kenhanu
Member Posts: 3
Will the hot water in a single zone system continue to circulate after the pump turns off? System is a copper ceiling installation.
The circulation would be the result of hot water rising and cool water falling.
It sure will. Not, perhaps, all that fast, but it will continue. There are many, many gravity hot water systems which did just that. The only thing that will stop it is a closed valve (a check valve may or may not).Br. Jamie, osb
Thank you. I thought that would help prevent possible freezing.
Previous owner had repairs done. I have added insulation to
reduce heat loss and protect pipes.
Kenhanu
Is this ceiling radiant? Yes it will there should be flow control valves on the supply piping. The tubes are small diameter 3/8" so gravity will not be real aggressive, but it will flow.0
comment. We lost power last winter in a 2 story home with a multi zone hot water baseboard system.
I used a battery with an inverter and connected to operate everything but the pump and I had hot water.
