Mini low heat heat pump?
overpop
Member Posts: 52
Is anyone aware of a heat pump that is small, doesn't need to get to a high temp as this will NOT be used for a home radiant application? At home I have the GE heat pump hot water heater but that would be a bit much for what I am thinking of doing although I could use that but it is expensive.
Kensa shoebox heat pump, fits in a kitchen cabinetBob "hot rod" Rohr
Cute. Do they have US distribution?0
Fantastic, exactly what I was looking for. Lets see if Kensa has distribution in US...0
