Insulating Flu Pipes.
njtommy
njtommy Member Posts: 1,105
The conversation came up today should you install insulation on the fresh air intake piping for 90% plus equipment. I don't think I've ever seen it done, but have any of you guys done so? Is it really worth it if the runs are long?
  • EzzyT
    EzzyT Member Posts: 1,377
    The only times I've ever had to do that was and when I've had to pipe both flue and fresh air to the outside of the building and beyond the 4' max of piping allowed in order to get the proper clearances but never have to do that on any of the piping inside of the building
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    njtommy
  • kcopp
    kcopp Member Posts: 4,630
    Just on the exhaust outside
  • CMadatMe
    CMadatMe Member Posts: 3,086
    If your fresh air is running thru any unconditioned space you should insulate in those areas to prevent condensing in the fresh air intake. Seen it many times. Worse thing is for that moisture to hit gas valves and wiring harnesses.
    njtommykcopp
  • njtommy
    Thanks guys.
    Sounds like it's not a bad idea to insulate the fresh air intake on longer runs even if it's a unconditioned basement.
