Form Follows Function
HeatingHelp
Administrator Posts: 718
This is really interesting!
Trends : in my neck of the woods 9' ceilings seem to be standard, big front porches are back, standby generators are common as are nanny quarters and furnaces in the basement and attic. Can you say ice dams! Since I read LAOSH back in the 90's I took Dan's advice and have always slept with a window open haven't had the flu since.
'm sure he was talking about the old wooden framed storm windows. Note he said " little mouse hole openings at the bottom." That was the older storms. You stuck your fingers in those holes to pull the bottom of the storm out to unhook the top and take them down in the summer.ChrisJ said:Our house was built in the 1860s, originally with wood stoves and it still has most of it's original single pane windows. A bit confused by "the double window came first" ?
We don't need to lower the ceilings, we need more radiant heat!0
My grandfather's house of a 100 years ago had some of the storm windows on hinges to open like a single shutter during the summer. The screen would then in snapped into place. (Storm windows were a pain to R&R and then store)
The storm windows had 3 1" holes drilled in the bottom frame, his had a flipper door on the inside pivoting on a screw to open during a mild day to get a little fresh air in. The wood storms would certainly beat the snot out of aluminum combo storm windows as far as air infiltration and conduction was concerned and they looked a lot better for sure. But were high maintenance and there were a lot of salesmen pushing the "new & improved" storm windows.0
- 62 Biomass
