Changing Nozzle - Electrode setting adjustment
360dean
Member Posts: 3
in Oil Heating
I read how to and accessed my oil furnace nozzle, so now I have got the right nozzle replacement ready to install and the electrodes appear to be in very good shape. I expect I will should remove the electrodes as the old nozzle is torqued on pretty good, so I'm thinking it is best to remove electrodes before attempting old nozzle removal. Plus, as the nozzle manufacturer is different, the length may not be identical and so I need to adjust the electrodes
I don’t have any gauge. Can I just measure before electrode dis-assembly and put back same distance on new nozzle?
Thanks for your help.
yes.... use a 3/4 and 5/8..... no vice grips please... and I hope you used a wrench on nozzle line and not pliers ....0
https://youtu.be/N6i2x08oI4o
I would recommend only handling the nozzle on the hex area intended for a wrench. Lessens the chance of fouling the filter on the back, or orifice on the front.0 -
I always pull them out and replace them. Cheap insurance0
Becket Z Gauge for me. Best 20 bucks I have ever paid for a little piece of plastic.hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
Every set of electrodes I buy has a little aluminum gauge in the bag.
If the points show any signs of wear, they get replaced. Sometimes they have to be bent a bit to set them perfectly.0 -
Yep. That's the T gauge. It definitely works, although I think the Z gauge allows for more accuracy, and is easier to use.
I usually change the electrodes once they are burned off so much that you can't bend them close enough anymore, unless the porcelains are really nasty. I like to hear everyone's preferences though. That's how we learn!1 -
since I've got a carlin I'm digging there 5 buck plastic setup tool that just slips over the head, put the electrodes in the slots, tighten up and your done.0
and if your changing the brand of nozzle will you be setting this unit up with at least a wet kit? changing the nozzle from spec can change the fire characteristics..
