covers
alanm
Member Posts: 120
I was wondering if radiator covers made from wood (with metal grate opening in the front only) hurt dispersing the heat? I have covers where the top is wood, the back is open, and the front has a metal grate . Should I remove them? should I do anything to them to make them better? I just want to make sure I am not hindering the heat (it is a one pipe steam system). Thanks
They most likely greatly reduce output.
There are designs which act similar to a convector and create a draft through the radiator which increase output but it's not a simple box with an open front and back.
I also feel all covers reduce the amount of radiation the radiator provides regardless of whether or not overall heat output is increased. I prefer radiation over convection my self.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Check this out- it pays to wander off the Wall:
https://heatinghelp.com/heating-museum/radiator-enclosures/All Steamed Up, Inc.
Consulting0 -
I have been considering doing something along the "deduct 10%" design for my son's room to increase the radiators output.Steamhead said:Check this out- it pays to wander off the Wall:
https://heatinghelp.com/heating-museum/radiator-enclosures/Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
@ChrisJ , I retrofitted a couple of my original covers and the difference was immediate. I can still close the tops in summer. I'd also suggest some relflective behind the rad and painting them in a matte colour.Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF1 -
My dreams, are to paint all of the radiators flat black.vaporvac said:@ChrisJ , I retrofitted a couple of my original covers and the difference was immediate. I can still close the tops in summer. I'd also suggest some relflective behind the rad and painting them in a matte colour.
I had also looked into buying glass mirrors to put behind them. Sadly, cost shut that idea down real fast.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I've wondered how much the "deduct X %" would be by adding a fan to the radiator to try and get more output.0
You might find this interesting
My covers fall into the "classic radiator cover" example. Has anyone had any experience with creating holes in the top lid? I'm sure a screwdriver would work but I was wondering if there is a way to "nicely" make hole punches in the sheet metal (taking the lid off and making the holes). Need to keep wife happy but wouldn't mind increasing efficiency
A step drill might be a good choice.0
