covers
I was wondering if radiator covers made from wood (with metal grate opening in the front only) hurt dispersing the heat? I have covers where the top is wood, the back is open, and the front has a metal grate . Should I remove them? should I do anything to them to make them better? I just want to make sure I am not hindering the heat (it is a one pipe steam system). Thanks
Leave a Comment
- 80.9K THE MAIN WALL
- 2.5K A-C, Heat Pumps & Refrigeration
- 36 Biomass
- 394 Carbon Monoxide Awareness
- 2.6K Controls
- 1.4K Domestic Hot Water
- 3.7K Gas Heating
- 101 Geothermal
- 130 Indoor-Air Quality
- 2.3K Oil Heating
- 30 Pipe Deterioration
- 565 Plumbing
- 4.2K Radiant Heating
- 333 Solar
- 12.2K Strictly Steam
- 36 Water Quality
- 7 Industry Classes
- 7 Recall Announcements
There are designs which act similar to a convector and create a draft through the radiator which increase output but it's not a simple box with an open front and back.
I also feel all covers reduce the amount of radiation the radiator provides regardless of whether or not overall heat output is increased. I prefer radiation over convection my self.
https://heatinghelp.com/heating-museum/radiator-enclosures/
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF
I had also looked into buying glass mirrors to put behind them. Sadly, cost shut that idea down real fast.
