275 gallon oil tank filled to 44 inches?
RobertL
Member Posts: 28
in Oil Heating
My oil company filled my tank as they have been for the last 20 years. Today I decided to stick the tank. Exactly 44 inches of oil, which equated to 275 gallons
I thought they left some headroom for my underground tank
yes the whistle extends into the tank warning the oil driver to cut off flow when tank is almost fill .
I was under the impression that it was almost impossible to get a full 44 inches in the tank.0
Obviously not.RobertL said:I was under the impression that it was almost impossible to get a full 44 inches in the tank.
My assumption was a 275 gallon tank was designed to hold 275 gallons so the actual tank is actually bigger than this. Maybe 280-285 if filled all the way?
I'm curious to see what others say as I'm sure someone here knows without a doubt.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
You can fill it all the way up if you have the nerve to keep going after the whistle stops and listen to the bubbles. Or, more likely, the driver filled to whistle stop, or a little more and the oil expanded from a very cold temp. Also if its an underground tank, the driver may use an underground fill adapter. In this scenario, the vent is pulled up to about 2" from the top of the tank. Also, being underground are you sure the top of the tank is 44"?
Ive never been able to put 275 gallon into an empty 275 tankThere was an error rendering this rich post.
Wow,
So a "275 gallon tank" is literally that size, so you can't use the full size under most conditions?
Reminds me of 32" CRT tvs that only 30" was visible.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Your vent whistle may no longer be operative. If this is the case, the driver only knows to stop when he actually hears the oil foaming in the vent pipe. This would get you a full tank. It is also a potentially dangerous situation. Did you run out?
Or...
You could have an odd-ball tank down there, and 44" may not equate to 275 gallons.
Did the driver leave you a slip with gallons delivered?New England SteamWorks
newenglandsteamworks.com0 -
260 is considered full. Tank needs some space for "wiggle room".
This is a BURIED 275???0 -
I think you have a 500 gallon underground tank. If I remember correctly, they are 48" round. I would also be careful not to drop the stick letting it hit the bottom harshly
>>>>>> This is a BURIED 275???<<<<<<<<<<
Yes, they are all buried in this development. Yes, he left a slip...0 -
LPG tanks are rated by water capacity - in pounds for DOT portable cylinders and in gallons for stationary tanks. A multiplier (specific to the fuel, the expected ambient temp limit, and the application) and is applied to that number to determine how much can safely be pumped into the tank. Roughly 80% of the gross capacity in most cases (though they used to fill them to 90%, at least where we lived.)ChrisJ said:So a "275 gallon tank" is literally that size, so you can't use the full size under most conditions?
Not 500 pounds of LPG.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Right, though the largest DOT tank I've seen is 420#. Multiply the W.C. number stamped on the ring by 0.42 and you get the weight of LPG the tank can hold.
A standard residential LPG tank has a 499 gallon capacity. Tanks that hold 500 gallons or more require a building setback increase from 10 feet to 25 feet, which is why you often see two or more 499's installed to serve large houses or light commercial jobs.0 -
We had a lot of those developments RobertL. Some were 275, some were 330, and not even actual tanks that were for the purpose of installing underground. I would consider getting it out of there, and install one above ground. Many insurance companies, up North here anyway, will not provide you coverage, nor will a bank lend money to a property that has one0
Right on. Don't think it's a STiP3
I've come across buried 275s, mostly flat. I would seriously look into removal and above ground replacement.
Thanks guys for your input
Regards0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
