Honeywell l6006c Aquastat wiring help please!
colnago
Member Posts: 2
New to water stoves and looking for help on wiring a Honeywell L6006c to only operate blower on stove. Trying to get fan to run til water temp of 180 reached and cut back on at 165 or so. I have tried running hot wire to R and running off B back to hot on fan. Whites from fan and power ran together. Doesn't seem to work and looking for help!!!
R-B opens, R-W closes on temp rise
R-B closes, R-W opens on temp fall
differential is adjustable, you can have up up to a 30f diff iirc.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/95-0000s/95-5973.pdf0 -
So, that would mean I have it wired correctly?0
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
