HTP Pioneer
EzzyT
Member Posts: 1,296
We ripped out a 12 year neglected munchkin that was also twice the size of the house's heat loss.
We Installed a HTP Pioneer 100 55 gallon high efficiency condensing modulating boiler with 4 taco sentry zone valves Caleffi air and dirtmag separators.
Taco Viridian pumps both on the heating system and for the indirect tank we also added a Caleffi mixing valve and expansion tank on the existing indirect tank.
Thank you Rich Mcgrath for the referral.
3
Why the delta P pump on the indirect tank?
Looks great0 -
I like it. It looks like quality!0
more options to play around with flow rates and ecm capability1
Thanks Harvey real easy to install and super simple to set up.0
Beautiful install ezzy t....but why no bronze pump on recirc line?....paul sASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Thanks Paul. It is a bronze pump that's one of the first things I looked at.
All we did with the indirect tank was add mixing valve and expansion tank. There was nothing wrong with the indirect tank, but we did give them a quote to replace it when that one goes0 -
Looks great Ezzy!!!LANGAN'S PLUMBING & HEATING LLC
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: langansph@yahoo.com
www.langansplumbing.com0 -
Interesting venting 3" to 2" to 3"?
Nice piping, thanks for the Caleffi use.Bob "hot rod" Rohr
Yeah I know, none of the supply houses had all the 2" polypropylene piping and fittings I would've needed to pipe the vent in 2" but they did have everything in 3" and the job was an emergency replacement.
No problem Bob0 -
I hear that quite often in my travels, suppliers do not carry the full inventory of adapters for that PP vent system.EzzyT said:Yeah I know, none of the supply houses had all the 2" polypropylene piping and fittings I would've needed to pipe the vent in 2" but they did have everything in 3" and the job was an emergency replacement.
No problem Bob
Hear in north nj there's only one supply house that stocks PP and they don't even have all but every other supplier says they can get it within a couple of days well that doesn't help when there's an emergency replacement or repair0
That's a problem. the exact same thing happened when stainless AL-29 was introduced many years ago as a better option to PVC. Since not many stocked the entire transition selection, installers gravitated to the readily available PVC. The same may happen to PP unless PVC gets pushed out by codes?
Of course the stainless was $$ and a challenge to cut easily.Bob "hot rod" Rohr
Real nice job Ezzy . Thanks for taking that northern job .
Little back story for everyone . Homeowner went to HTP supplier after Langans or Browndog was not available . They recommended 2 contractors who then recommended and gave prices for equipment not even handled by that supplier . Heat loss was 65000 as per Ezzy , one recommended a Utica 95M (80K- 200K) the other recommended a Navien NR 240 A . Homeowner contacted me for advice on those choices . Luckily by then I had learned that Ezzy was available to do the boiler .
Witj a little cooperation and relationships between contractors we could probably lessen the amount of bad stuff that happens or gets installed .
Ezzy's employer contacted us within 2 days to inquire about us looking at something 3 hours from them adn a bit south of us . We are presently figuring out what must happen there . Thanks Corrado and Ezzy .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38332 -
Thanks Rich and thanks for the referral.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
