HTP Pioneer
EzzyT
EzzyT Member Posts: 1,377
We ripped out a 12 year neglected munchkin that was also twice the size of the house's heat loss.
We Installed a HTP Pioneer 100 55 gallon high efficiency condensing modulating boiler with 4 taco sentry zone valves Caleffi air and dirtmag separators.
Taco Viridian pumps both on the heating system and for the indirect tank we also added a Caleffi mixing valve and expansion tank on the existing indirect tank.
Thank you Rich Mcgrath for the referral.
E-Travis Mechanical LLC
Etravismechanical@gmail.com
201-887-8856
njtommyHarvey Ramer4Johnpipe
  • njtommy
    njtommy Member Posts: 1,105
    Why the delta P pump on the indirect tank?
    Looks great
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,281
    I like it. It looks like quality!
  • EzzyT
    more options to play around with flow rates and ecm capability
    201-887-8856
    njtommy
  • EzzyT
    Thanks Harvey real easy to install and super simple to set up.
    201-887-8856
  • Paul S_3
    Paul S_3 Member Posts: 1,291
    edited January 2016
    Beautiful install ezzy t....but why no bronze pump on recirc line?....paul s
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
  • EzzyT
    Thanks Paul. It is a bronze pump that's one of the first things I looked at.
    All we did with the indirect tank was add mixing valve and expansion tank. There was nothing wrong with the indirect tank, but we did give them a quote to replace it when that one goes
    201-887-8856
  • 4Johnpipe
    4Johnpipe Member Posts: 488
    Looks great Ezzy!!!
    LANGAN'S PLUMBING & HEATING LLC
    Considerate People, Considerate Service, Consider It Done!
    732-751-1560
    email: langansph@yahoo.com
    www.langansplumbing.com
  • EzzyT
    Thanks John
    201-887-8856
    hot_rod Member Posts: 26,584
    Interesting venting 3" to 2" to 3"?
    Nice piping, thanks for the Caleffi use.
  • EzzyT
    Yeah I know, none of the supply houses had all the 2" polypropylene piping and fittings I would've needed to pipe the vent in 2" but they did have everything in 3" and the job was an emergency replacement.
    No problem Bob
    201-887-8856
    No problem Bob
    I hear that quite often in my travels, suppliers do not carry the full inventory of adapters for that PP vent system.
  • EzzyT
    Hear in north nj there's only one supply house that stocks PP and they don't even have all but every other supplier says they can get it within a couple of days well that doesn't help when there's an emergency replacement or repair
    201-887-8856
    That's a problem. the exact same thing happened when stainless AL-29 was introduced many years ago as a better option to PVC. Since not many stocked the entire transition selection, installers gravitated to the readily available PVC. The same may happen to PP unless PVC gets pushed out by codes?
    Of course the stainless was $$ and a challenge to cut easily.
  • Rich_49
    Rich_49 Member Posts: 2,785
    Real nice job Ezzy . Thanks for taking that northern job .
    Little back story for everyone . Homeowner went to HTP supplier after Langans or Browndog was not available . They recommended 2 contractors who then recommended and gave prices for equipment not even handled by that supplier . Heat loss was 65000 as per Ezzy , one recommended a Utica 95M (80K- 200K) the other recommended a Navien NR 240 A . Homeowner contacted me for advice on those choices . Luckily by then I had learned that Ezzy was available to do the boiler .
    Witj a little cooperation and relationships between contractors we could probably lessen the amount of bad stuff that happens or gets installed .
    Ezzy's employer contacted us within 2 days to inquire about us looking at something 3 hours from them adn a bit south of us . We are presently figuring out what must happen there . Thanks Corrado and Ezzy .
    You didn't get what you didn't pay for and it will never be what you thought it would .
    732-751-1560
    Rich McGrath 732-581-3833
    jonny884Johnpipe
  • EzzyT
    Thanks Rich and thanks for the referral.
    201-887-8856
