Pipes
I live in a mobile home and I let my water run in the bathroom last night. I woke up this morning and it was still running so I turned it off and did laundry this morning for 2 hours and afterwards my daughter went to turn it on about 2 hours later and my pipes were frozen. Any idea what I can do to u thaw them.
Open them back up (faucets that is) for starters.
If there are any cabinets like kitchen sink base cabinet or bathroom lavatory vanity cabinet that these water lines run through, open the doors to allow the heat from the room to warm them back up. You could try using a hair dryer to heat them up as well.
Good luck!
Robert O'Connor/NJ0 -
Where are you located and did it freeze last year?
If you have a "cold climate" mobile home, built for northern freezing weather then the water lines are usually run up inside the insulation with the ductwork....maybe. The water service line under the home however is usually protected with a heat tape from as low in the ground as possible to well within the insulation. Your heat tape may have failed or has no power to it.
Sometimes the solution is to open the skirting and stick a heavy duty heater in the opening. Something like a "Knipko" fuel oil or propane temporary construction heater. Then check the heat tape after thaw out.0
- 117 Geothermal
