Crane Thin Tube Radiators. EDR not in books
JUGHNE
Member Posts: 11,547
I have a schoolhouse full of these. 33" tall--3 tube and 4 tube, 4.5" and 6.5" section width.
I was going to use 3 EDR and 3.5 EDR as a best guess for those.
(There are two 4 tubers with 35 sections & center leg, 87.5" long, someone earned their pay with those)
But then there are some 39.5" tall 3 tube, 4.5" section width.
Then basement ceiling radiators, 28.5" "tall" 2 tubes and some 21.5" "tall" with 2 tubes per section.
Does anyone know EDR for the tall boys and ceiling rads? Thanks
1
I have some charts from and old ASHRAE book. For your 33" (32") tall 3 tube I show 3 sq ft, for the 4 tube I show 3.5 sq ft.
For the 39.5" tall, I show 38" tall by 3 tubes at 3.5 sq ft.
I don't have any information for this type of ceiling radiator.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Thanks Dave, the ceiling rads are almost like small column units.
My best guess for the 28" to use 2.8 EDR and for the 21.5" to use 2 EDR. The only concern to get close is for orifice sizing and I will start out small.
I added a picture of interest, a brass valve brazed directly onto a 1" riser steel pipe......something you would have seen during the 30's when people had more time than money, but the TRV indicates that it was more recent than the depression.....also note that there a coupling below just above the floor!0 -
- 169 Indoor-Air Quality
- 50 Industry Classes
