All Hot water in the house is cloudy but clears up after sitting awhile. What has caused this?
All hot water in the house is cloudy but clears up after sitting awhile. What has caused this?
  • MikeSpeed6030
    MikeSpeed6030 Member Posts: 69
    Probably air entrained in the water. The solubility of air in water drops as temp increases. When the water cools, the air goes back into solution.
    Are you on city water or a well system?
  • SWEI
    SWEI Member Posts: 7,342
    Tiny air bubbles.
  • A.J.
    A.J. Member Posts: 257
    Probably the anode rod in your hot water tank Is over active and releasing hydrogen into the tank . Change it out especially if the tank is over 5 years old.
