Selection of a pump for a hot water loop off steam boiler
Abracadabra
Abracadabra Member Posts: 1,948
I've been requested to install a hot water loop off a steam boiler. Loop will be about 325-350' of 3/4 copper including the approx. 50' of slant/fin baseboard. What pump am I using here? I'll be pumping boiler condensate instead of going thru a heat exchanger, so I'll need a brass pump. What does everyone use? Standard B&G 100AB? Anything more efficient?
