Honeywell Digital T-stat
Honeywell T-stat issues0
Do I have this right? You have two separate thermostats reading a room temp. of 85* when the actual temp is 64*?Steve Minnich0
If that's right, is there some sort of heat source, light, etc near the stat?Steve Minnich0
If the only thing you had to do, was set the dip-switches, and you have the same problem with both t-stats.....what HAS to be the problem? Just sayin'0
The 2nd floor is fine and not an issue. I replaced the 1st floor unit which is on an interior wall in the living room away from any lights. The boiler does have two zone valves that are working fine with resistors.0
what is the model number of the stat?0
Many of Honeywell T-Stats come with a clear/black thin film over the screen that says 85 degrees on it. It is a scratch protector that you need to peel off. Are you sure that isn't the case here?0
Put the second floor stat on the 1st fl and see what happens.0
Put it in a refrigerator and see if it says 64.
Guys, I really think it was the printed protective film over the display screen. It does look pretty much like the real display.0
That certainly is the simplest explanation for what would otherwise be a real head-scratcher.0
There is no film. This is a real issue that I will have to call Honeywell
Let us know what you find out. Many of us use & recommend Honeywell stats, something like this is important to know.0
I have been having an issue with a Honeywell T8775a Digital T-stat. When I spoke Honeywell they told me to make sure they is no lamp near by, plug the hole where the wire comes thru the wall to make sure no heat is hitting the back. ( just an unheated basement below.) Upon doing a voltage test they suggested that adding an additional 24v transformer "might" help the situation. Now, I know that a 24v transformer will work 3 zone valves. With two zone valves and an existing 24v transformer their digital t-stat draws too much power to operate. After four trips to the customers home I finally put on a battery powered digital t-stat for them and all is good. I made NO money on this job and Honeywell will not compensate me for their power draining t-stat issues. They make other good products that I like and use. Guys, DO NOT use Honeywell T8775a Digital T-stats with zone valve! Install a cheap battery powered one and save yourself the headaches. Ray Hurilla Plumbing & Heating Co.0
I had considered using the T8775A on a recent project.RayH said:I have been having an issue with a Honeywell T8775a Digital T-stat. When I spoke Honeywell they told me to make sure they is no lamp near by, plug the hole where the wire comes thru the wall to make sure no heat is hitting the back. ( just an unheated basement below.) Upon doing a voltage test they suggested that adding an additional 24v transformer "might" help the situation. Now, I know that a 24v transformer will work 3 zone valves. With two zone valves and an existing 24v transformer their digital t-stat draws too much power to operate. After four trips to the customers home I finally put on a battery powered digital t-stat for them and all is good. I made NO money on this job and Honeywell will not compensate me for their power draining t-stat issues. They make other good products that I like and use. Guys, DO NOT use Honeywell T8775a Digital T-stats with zone valve! Install a cheap battery powered one and save yourself the headaches. Ray Hurilla Plumbing & Heating Co.
I assume this didn't have a common wire?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
just red & white
