Stainless steel chimney require a ground
Geraldo
Member Posts: 16
in Oil Heating
I know if you install a tv antenna or other things they need a seperate ground. The chimney is mounted but I don't see any ground.
A metal duct running from the highest point on the roof (or nearly so) to the basement should definitely be bonded -- preferably to the service entrance grounding electrode system, but at least to an existing metal water pipe or other buried metallic items.
A separate ground rod can be used, but it must be bonded to the electrical service grounding electrode system. While you're at it, go ahead and bond your gas or oil pipe(s) too.0 -
I've been trying to figure out if my aluminum siding should be bonded and so far all I've found is, no. And that amazes me.
Not for lightning reasons, but if you had something that somehow shorted to the siding, it'd all, or mostly all be hot.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Technically it should be bonded, but it's not all that easy to bond the backside of a thin piece of sheet metal without a bunch of ugly screw heads showing through. On new construction we install at least one metal stud or a vertical metal channel on each wall, then bond the bottoms of those to something suitable. Screwing the siding into the vertical metal piece ties everything together electrically. Done right, you end up with a moderately decent Faraday cage.0
