Can i use furnace sealant to replace a gas heater firebox sealant
matthew_rogers
Member Posts: 33
quick feedback wanted.
i just cleaned the burner tubes in my gas heater
i removed the back hatch and slightly weakened the back firewall calking while removing a stubborn screw.
(this firewall piece is abt 6"x8" and soft: resembling soft kaowool and the color of firebrick)
there was a white sealant applied to the top of this small pad
this sealant insured a tight seal between the top of the pad and the base of the metal radiator sections.
this white sealant was loose when i first noticed it, and fell off as i removed the back plate.
i have furnace sealant on hand (black) but i know its 2000 degree rated and hard curing.
i figured the hard sealant that has fallen off (white colored) was essentially the same material.
i am about to:
#1 put a bead of my black furnace sealant on the firewall pad to replicate the pre-existing white sealant.
#2 i will slide it up to meet the radiator and screw the back plate back on.
#3 I will let it air dry 1hr
#4 and then fire up the heater.
am i making a decent 1:1 fix? (temperature is dropping here in MA)
i am about to:
i went ahead with the sealant patch, a Plumber/Heating contractor looked at it, shrugged and said it was fine. I'd prefer a bit more chemistry in his shrug.
does anyone know what sort of MSDS i could pull to identify the compound used to seal the seams in a forced hot water boiler?
I will then compare it to the furnace sealant i used to seam my boiler.0 -
Go to a plumbing and heating supply and bring what ever you used and ask them if it is acceptable for what you did. That is for your sake the simplest approach.0
thanks, will do0
only feedback i get from all plumbers and vendors is a shrug.
firebox is tight now and sealant is hard.
specs on the product i used did specify ratings for repairing fireboxes and the like.
besides its just functioning as a tiny bit of air sealant (2000 degree caulking)0 -
What is the exact information on what you used and I will look it up for you as to application. Need manufacturer name and perhaps a picture of the tube, can etc.0
product i used:Tim McElwain said:What is the exact information on what you used and I will look it up for you as to application. Need manufacturer name and perhaps a picture of the tube, can etc.
rutland furnace cement
upc: 022624000655
product name: No65
outer frame is nice and cool for last couple days since i introduced this product to replace the cracked/loose/missing material.0 -
Furnace cement does not work well with high temps it will dry out and you will have the same problem. You need a refractory cement for what you did.0
- 110 Chimneys & Flues
- 982 Plumbing
- 387 Solar
