Set point tempurature
rjdan
rjdan Member Posts: 1
hello i have a Burnham hydronics freedom boiler, and the set point temperature is too low. The boiler comes on at around 110, as a result all 4 zones are only 62 degrees and the thermostat is set to 68. It seems to shut off around 128 degrees. Giving a code that the et point temperature has been reached. It is cold outside 20 degrees. Is there a way to reset it?
  • Tim McElwain
    Tim McElwain Member Posts: 4,659
    Do you have the manual for the boiler? If so there is a procedure for resetting the set point in the manual. If you are not comfortable with fooling with it call your local Burnham dealer and I am sure they can help you.
