Steam Radiator Vent
tag73
Member Posts: 2
I replaced my old Maid-o-Mist steam radiator vent with an identical Maid-o-Mist Jacobus "D" circular-style vent. I cannot turn it enough to completely tighten it into the radiator and have the vent pointed upwards. Any suggestions?
How loose is it? Did it bottom out or not enough turns?
Add another wrap or two of PTFE tape to it and see if you can get it to snug up in the right spot. It doesn't need to be crazy tight.
EDIT : On second thought, wasn't there something about the threads on MOM vents being wrong?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
A couple of years back there was a batch of them that appeared to have straight threads instead of tapered threads. I bought 4 vents and had to run a 1/8 NPT die over them to get them to fit my radiators.
Don't force it or you might crack the radiator casting.
3PSI gauge0 -
This. If the valve takes 3-4 turns you're good. You don't need to hold back more pressure than 1.5 psi, if that.ChrisJ said:
- 50 Industry Classes
