Off the Wall
Steve Minnich
Steve Minnich Member Posts: 2,868
https://heatinghelp.com/assets/documents/95.pdf
Found this gem wandering off the Wall.
And we think pex is hard to work with when cold.
Steve Minnich
ChrisJErin Holohan Haskell
  • ChrisJ
    ChrisJ Member Posts: 17,069
    edited January 2016
    A lot of guys seem to think sweating copper is hard.
    Poor babies have so rough these days.............
    The hands of a modern plumber. :)
    vaporvac
  • Rich_49
    Rich_49 Member Posts: 2,785
    I beg your pardon ? Speak for the sissies
    732-751-1560
    Rich McGrath 732-581-3833
  • ChrisJ
    You lost that betting your Zippo could light every time for a new Cadillac, didn't you? In all seriousness, is that your hand?
  • Rich_49
    edited January 2016
    YEP , that's my hand , You aint seeing one like that in a Palmolive commercial
    732-751-1560
    ChrisJjonny88
  • vaporvac
    vaporvac Member Posts: 1,520
    @ChrisJ , did you notice the steam apps in that pdf?
  • ChrisJ
    Nope, I'll have a look at it later.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    Byers wow blast from the past. My Da installed that for radiant heat in a Church in Lenox, MA the whole system failed within 2 years time. Turned out the fill the contractor used was corrosive. He will share that story as a warning to anyone who wants to install radiant heating. Talk about leaving a bad taste in your mouth. Yes he was initially sued and accused of substituting regular iron pipe for the wrought iron pipe. Forensics proved it was all Byers piping.
    cell # 413-841-6726
  • Boiler wrestler
    Boiler wrestler Member Posts: 43
    The Stanley Residence is still going strong. Its on page 36.
    I have to admit it threw me for a loop when I saw it first. It was piped with bypass zone valves in the field loops for the zones, off was on and on was off. Bleed ing out was quite the scavenger hunt.
  • jonny88
    jonny88 Member Posts: 1,139
    Fig 67 wow.@Rich that was an owww moment
  • Gordy
    Gordy Member Posts: 9,546
    I'll bet it's still an owwie factor when it gets bumped...especially in the cold......ooooooh watch out for stubby!
    Did everyone read page 52? Yes that applied in spades. Greater Grace Church I think was the name.
    cell # 413-841-6726
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    It really does pay to wander off The Wall. And Erin and I will keep adding more. Thanks for pointing it out Stephen.
    Retired and loving it.
  • Abracadabra
    iron pipe in concrete? ewwww....
