Steam Radiator Vent
I replaced my old Maid-o-Mist steam radiator vent with an identical Maid-o-Mist Jacobus "D" circular-style vent. I cannot turn it enough to completely tighten it into the radiator and have the vent pointed upwards. Any suggestions?
  • ChrisJ
    ChrisJ Member Posts: 17,341
    edited January 2016
    How loose is it? Did it bottom out or not enough turns?
    Add another wrap or two of PTFE tape to it and see if you can get it to snug up in the right spot. It doesn't need to be crazy tight.
    EDIT : On second thought, wasn't there something about the threads on MOM vents being wrong?
  • BobC
    BobC Member Posts: 5,565
    edited January 2016
    A couple of years back there was a batch of them that appeared to have straight threads instead of tapered threads. I bought 4 vents and had to run a 1/8 NPT die over them to get them to fit my radiators.
    Don't force it or you might crack the radiator casting.
    Bob
    3PSI gauge
  • Abracadabra
    This. If the valve takes 3-4 turns you're good. You don't need to hold back more pressure than 1.5 psi, if that.
  • tag73
    tag73 Member Posts: 2
    It was the threads. Bought another one at a different store and had no problem. Thanks for the insight here.
    ChrisJ
