Keep steam or convert to hot air
cogswell
Member Posts: 2
We are trying to decide whether to keep a two pipe steam system in an old school (1891) in Haverhill, MA that we want to re-purpose as an art center. The building is 15000 sq. ft. The boiler is shot. Does anyone in my area work on commercial sized steam systems? We are being told that the old system is too inefficient to use. Is this true? All recommendations seem to be to put in 8 separate residential hot air units with AC capability, but I wonder whether that is because these people don't know or understand a steam system.
It's because the people you have talked to have no idea what they're talking about.
Find a steam man and have the current system fixed.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Keep the steam. Install thermostatic radiator valves in each unit and cycle the boiler with a Tekmar or Heat-Timer control. If you want to do A/C, use a mini-split in each room.All Steamed Up, Inc.
Consulting1 -
Two-pipe steam systems are capable of superb evenness, economy and quietness, if properly installed.
The alternative, in forced air will cause the building to be encumbered with many unsightly ducts, and roof penetrations for exhaust flues.
While you are waiting for JA to have a look, post some pictures of the existing boiler, and it's piping, as well as a few radiators, and you will start to get lots of professional advice.--NBC0 -
Many of us on this site have one thing in common and that is Dan's book "The Lost ART of Steam Heating". As has been famously said this method of heating is an Art in itself.
To tear out a steam system and then to blast open the walls for ductwork would be gutting an old building that is probably a piece of art history itself.
Some members of the 100 year old church wanted to put covers over the cast rads because they looked old. I asked if they would put drapes over the stained glass windows also. No comment.
Some people want to tear out what they don't understand or refuse to learn about. More quick money is to be made by new install than repair of old. There has to be some steam people close.0 -
If JA is busy call me.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
When a contractor "recommends " replacement of an entire system. it should be noted that it's supposed to be "energy efficient" as defined by the DOE. The DOE suggests it (new system) should pay for itself over ten years.
There is no way switching out an entire system that size will pay for itself in ten years. Frankly, I don't see it paying for itself in your lifetime.
Be careful who you get, but get a steam pro fast.
The system (especially a 2 pipe) is worth saving.
Robert O'Connor/NJ1 -
Contrary to what US DOE says steam is the most economic way to heat. On account of so little wear and maintenance and so little electricity needed to transport the heat.0
I have experienced the environment in many buildings through the years, some with hot air and others with radiant heat. Radiant systems, whether hot water or cast iron have been more comfortable in almost all cases. The cost of steam is very competitive, and in most cases will be as efficient as so called high efficiency systems. Most forced air systems when installed into a converted school building will be visually obstrusive. Noisy, drafty, and generally inadequate. The main reason steam is no longer being installed is the initial high cost to install.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
That's where the mini-tube systems come in.Dave in QCA said:The main reason steam is no longer being installed is the initial high cost to install.
Consulting0 -
@Steamhead Indeed! And, it would seem the install cost is less than hot water. Cast iron makes it so nice, wish the cost of dads was less. It would also seem that minitube would work well with cast iron baseboard. Perhaps goverale govray installed recessed....Dave in Quad Cities, America
Modern hot water heating systems that are properly sized, designed, installed, and commissioned can approach theoretical efficiency limits as long as the space has regular daily occupancy. Igor's modern vacuum system can probably match (and may well exceed) this level of performance.
For buildings in cold climates that have intermittent occupancy (most especially older, less insulated ones) nothing can touch a good steam system.
Nobody will try but a modern steam system need not be so expensive. Air is free except for furnace if ducts for AC are put in anyhow.0
Thank you all for your input. I will try to get one of your recommended contractors to come out to give me an idea of what I am dealing with.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
