water meter
Flip
Member Posts: 40
Anyone know of a place to get a water meter to pipe into my boiler make up water line.
These guys also have them.
http://www.jerman.com/dljmeter.html0 -
Cleveland Plumbing Supply gets them for me. Im sure they would take a phone order. Ask for Dave Honkalagwgillplumbingandheating.com
watermeters.com, of course. It should be low lead brass if it connects to a potable water supply, or a composite body..Bob "hot rod" Rohr
Or just keep it after the backflow preventer, no?hot rod said:watermeters.com, of course. It should be low lead brass if it connects to a potable water supply, or a composite body..
Officially BFDs are supposed to be LF. There is a carve out for boiler feed devices, but not all inspectors know or interpret that.ChrisJ said:
If the meter is just for the boiler and downstream of the BFD, that should fly as you suggested.
http://axiomind.sasktelwebhosting.com/meter.php
Axiom has a flow/conductivity meter that's designed to be installed on a makeup water line. See the link above.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
- 79 Pipe Deterioration
- 396 Solar
