water meter
Anyone know of a place to get a water meter to pipe into my boiler make up water line.
  • These guys also have them.
    http://www.jerman.com/dljmeter.html
  • gerry gill
    gerry gill Posts: 3,084
    Cleveland Plumbing Supply gets them for me. Im sure they would take a phone order. Ask for Dave Honkala
    gwgillplumbingandheating.com
    hot_rod Posts: 28,343
    watermeters.com, of course. It should be low lead brass if it connects to a potable water supply, or a composite body..
  • ChrisJ
    ChrisJ Posts: 17,675
    Or just keep it after the backflow preventer, no?
    Officially BFDs are supposed to be LF. There is a carve out for boiler feed devices, but not all inspectors know or interpret that.
    If the meter is just for the boiler and downstream of the BFD, that should fly as you suggested.
  • http://axiomind.sasktelwebhosting.com/meter.php
    Axiom has a flow/conductivity meter that's designed to be installed on a makeup water line. See the link above.
