water meter
Flip
Flip Member Posts: 40
Anyone know of a place to get a water meter to pipe into my boiler make up water line.
  • Jean-David Beyer
    These guys also have them.
    http://www.jerman.com/dljmeter.html
  • gerry gill
    gerry gill Member Posts: 3,083
    Cleveland Plumbing Supply gets them for me. Im sure they would take a phone order. Ask for Dave Honkala
    gwgillplumbingandheating.com
    hot_rod Member Posts: 26,579
    watermeters.com, of course. It should be low lead brass if it connects to a potable water supply, or a composite body..
  • ChrisJ
    ChrisJ Member Posts: 17,068
    Or just keep it after the backflow preventer, no?
    Officially BFDs are supposed to be LF. There is a carve out for boiler feed devices, but not all inspectors know or interpret that.
    If the meter is just for the boiler and downstream of the BFD, that should fly as you suggested.
  • Captain
    Captain Member Posts: 30
    http://axiomind.sasktelwebhosting.com/meter.php
    Axiom has a flow/conductivity meter that's designed to be installed on a makeup water line. See the link above.
