Honeywell TRV replacement?
kozemchuk
Member Posts: 3
First post here. I've searched the forums but haven't been able to find an answer, please point me in the right direction if I missed something.
I'm looking for a replacement TRV that doesn't include the entire valve body - is such a thing available? The piece I'm talking about is circled in the picture. We use Honeywell actuators and it's a two pipe system.
Thanks!
Thanks!
Contact the valve manufacturer, and ask if components are sold separately.0
You might try checking with Supplyhouse.com. They are a favorite for many folks on here. I have found what I think is the part you're looking for. Here is the link below. Also note there is good information on the submittal sheet link.
http://www.supplyhouse.com/Honeywell-Braukmann-CA110C107-Replacement-Cartridge-for-V110
Hope this is helpful.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Thanks Dave!0
Yikes.....$75 for the socket to change it.0
Yeah I saw that... we have 95 units, all steam heat, so it will pay for itself fairly quickly.
Anyone know of a cheaper tool? Would a regular fixed pin spanner wrench work?0 -
Look at the tunstall website www.tunstall-inc.com
While there under the Maconcontrols tab you will notice inserts for a variety of SCV manufacturers along with inserts to turn a hand radiator valve into a scv.0 -
the part number is "RSBRK" for the insert assembly. with that quantity we can provide a tool to remove the existing insert. you will have to purchase a new Macon operator. see the website: www.maconcontrols.com0
- 120 Geothermal
