New Burnham MegaSteam Install
The pictures are loading very slowly for me.
Have you compared the piping sizes and layout with what is required in the manual for the boiler?
You may need to skim several times more than the installers will, so make sure to watch the process. Squick, and various other treatments will not be a substitute for th old fashioned way.--NBC
As the pictures are very dark, I cannot see the skim port-is there one?0 -
The pics wont load for me but congrats. I had to skim mine a good bit initially , and I was careful on my install with wiping out oil from pipes and such. I also used some old auto wax on the jacket , just because I have seen some dumb stuff in the past ruin paint on these.hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
That looks good from here, not stellar (going up a size on the header would be better) but I'm sure it will serve you well.
It will have a few skimming sessions to get that water clean. Gid they install new air vents?
3PSI gauge0 -
Off subject, How old are those oil tanks? From here looks like it's time0
What are the settings on the vaporstat? A 0-3 psi low-pressure gauge would keep those settings honest as well.--NBC
And have you checked for any system leaks, which may have rotted out its predecessor? A water meter on the feed would be useful here.0 -
That looks like a pressuretrol, not a vaporstat, and it looks like they've cranked it up pretty high.
The wiring looks sloppy, unless they just did that to not leave you without heat. Hopefully that will all get cleaned up.0 -
Gentelmen,
Thank you for your responses. I have attached pictures of the final install. So far, so good. Not sure I'm a fan of the cycle guard low water cut off.
Yes. I watched him skim it. Didn't seem like a lot of oil, etc, came out. But I will skim it again. Is it best to skim when the boiler / system is cold? eg - not fired for 24 hours?nicholas bonham-carter said:
No. Should they have?BobC said:Did they install new air vents?
Bob
Completely on topic IMHO. The installer said it's time. The tanks are ancient. Any recommendations on the tanks? They will be a PIA to get into the basement.Marz said:Off subject, How old are those oil tanks? From here looks like it's time
I have no idea what vaporstat settings are. How do I check? I have looked around the radiators for leaks, and the steam loops in the basement, but haven't found any.nicholas bonham-carter said:What are the settings on the vaporstat? A 0-3 psi low-pressure gauge would keep those settings honest as well.--NBC
Will the water feeder I have also meter it? They reset it and it says 2 after they filled the boiler to fire it.
What should the pressuretrol be set to? They cleaned up the wiring etc today. Initial pics were just so I would have heat for the night.Abracadabra said:That looks like a pressuretrol, not a vaporstat, and it looks like they've cranked it up pretty high.
I like the spin on filter + vacuum gauge.
This has me wondering if it is worthwhile to install the outside air ducting on mine .
Years ago I lived in a house with hot water heat and I wanted the box mount and box cover for my AFG at the time. Now I have that on my MST and I don't really want to use it , lol.Yes. I watched him skim it. Didn't seem like a lot of oil, etc, came out. But I will skim it again. Is it best to skim when the boiler / system is cold? eg - not fired for 24 hours?
You want to do this when the boiler is hot ( my preference ) but some say that cold works just as well. I feel that the oils are more " fluid " when everything is hot ( versus cold ). I have a nipple and a tee facing down coming from my skim tapping. I have a boiler drain into the tee , when I want to skim I connect a hose and open the boiler drain. I manually open my fresh water fill valve just barely enough to cause the level to rise and trickle from the hose. I leave it like this for 2-3 hours at a time. The oils that cause problems may not be visible like you think , merely a " sheen " that floats on the surface of clear water is all it takes .hvacfreak
I keep a 2 inch 90 and a nipple to use in place of that plug to add cleaner and such. I keep a piece of 3/8 all thread near by to use as a Steamaster plunger.hvacfreak
I'm old school, I like the simple cartridge filter, less waste.ChrisJ said:I like the spin on filter + vacuum gauge.
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
If they used a 007 circulator set aside some money for getting a proper 3 piece circulator for when that dies in a couple years. There should be a bypass on the circulator piping to prevent water flashing to steam in the circulator. Looks like they assembled the piping kit as per the instructions. Does that supply tap enter a bull head tee or is there only one loop of the system?Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 110 Chimneys & Flues
- 106 Geothermal
- 983 Plumbing
- 387 Solar
