Hydro Coil
Bill_31
Member Posts: 6
Want to use a Bosch Tankless, water heater to support a Unico hot water coil (heating only)
ok well it's doable should be no problems but we need more information.
What water temp do you need to supply enough btus to your coil?0 -
Why?
Tankless heaters are designed for low flow, high delta T operation. The small diameter HX tubes typically require a high head circ to get any performance, and may not ramp to full burner output with a pumped flow.
Use a boiler designed for the application and enjoy all the added benefits, ODR, ramp and delay functions, warranty, and piece of mind.
You have chosen a good brand, but the wrong product, look into their boiler options.Bob "hot rod" Rohr
Living the hydronic dream1
