Hydro Coil
Bill_31
Bill_31 Member Posts: 6
Want to use a Bosch Tankless, water heater to support a Unico hot water coil (heating only)
  • njtommy
    njtommy Member Posts: 1,105
    ok well it's doable should be no problems but we need more information.
    What water temp do you need to supply enough btus to your coil?
    hot_rod Member Posts: 25,365
    Why?
    Tankless heaters are designed for low flow, high delta T operation. The small diameter HX tubes typically require a high head circ to get any performance, and may not ramp to full burner output with a pumped flow.
    Use a boiler designed for the application and enjoy all the added benefits, ODR, ramp and delay functions, warranty, and piece of mind.
    You have chosen a good brand, but the wrong product, look into their boiler options.
    SWEI
