Burner identification?
iix
Member Posts: 18
Ran into a older oil burner the other day, couldn't find any markings on it to identify it. Closest I could come up with was a Heatwise BK-1 although the layout for some of the controls are different.
Does the cover come off? All I see is an oil pump and delayed oil valve.
Edit: This was about all I could find.
http://www.butkus.org/furnace/heatwise_bk1_burner.htm
Edit 2: Same guy also posted a PDF manual for it.
http://www.butkus.org/information/slant_fin/heatwise_bk-1_burner.pdf0 -
Heatwise from early 90's0
There are very few 2 pipe jobs around here, mostly older systems, but the ones that do usually have a valve on them. Mostly because almost all our fuel tanks are above ground on a stand. Nothing worse than trying to take a fuel line off when you can't shut it off. I will take the handles off these valves and tie it to the pipe for future use.
We do have a couple of underground tanks, and these don't have valves on the return.
And I know, don't use 2 line systems, which I don't. 99% of all our jobs is a fuel tank outside with a single line coming in at about the same level as the burner.
Slightly highjacked thread. Sorry.
Rick0 -
I know you have paid your dues Rick, just a heads up for the OP. Got some snow up your way Rick? Been enjoying a mild season so far on the south shore of Mass0
After 110 inches of snow last winter we deserve a little break.
At 69 I really don't want to shovel snow off the roof and deal with ice dams this year. Although I will say I have a lovely view of Quincy bay if I stand next to the chimney.
3PSI gauge0 -
Heat wise or pioneer Burner they are now out of buisiness I know they made some burners for dedetrich boilers in the late 90's . The previous burner design was the ertly that was late 70's early 80's they came on Dan heat boilers.0
Thanks guys0
Oertli American was an ABC burner. Was Heatwise the ones who made those sweet things?0
- 120 Geothermal
