Furnace shutting down
laube77
Member Posts: 1
in Oil Heating
We have a well McLain oil furnace shutting down. The error code is the thermostat. Does that mean it needs to be replaced?
Hi there, Is it if you feel that some rooms are too cold while others are too hot? If your furnace is not able to distribute the air properly to keep you comfortable and is quite old, then furnace repair service NJ can be needed or may be even require replacement.-1
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
