Radiant pex fittings - poly or brass?
crobar
Member Posts: 4
I am running some pex piping to a couple of hot water radiators. I can't find any info on the temp. limit for the poly fittings - are they OK to use on the heating system piping or only for potable systems? Thanks.
I wouldn't even use poly fitting for domestic.... unless its Uponor (cold-expansion joints).0
I've had 0 issues with Uponor or Viega EP fittings for heat.0
- 120 Geothermal
