Heat not working
cubs786
Member Posts: 2
I have water heating system in my two apartment building the heat was working fine yesterday but this morning the motor (bell and grosser series 100) is not running or making any noise.I changed the temperature setting to 75 to see if the heat comes on but no.What could be the reason for heat not to work.thanks.
Really nowhere near enough info -- type of boiler and fuel would be helpful, for instance. But as a first cut, are you getting power to the boiler? Is the thermostat actually closing the circuit?Br. Jamie, osb
Yea,......very vague. Kill the power supply to system then back on. See if that resets the system. Other than that, like Jamie said could be anything.0
- 15.8K Strictly Steam
