Hydronic Baseboard Heat - 3 Zones - Please Help
Jbaile38
Member Posts: 2
Hello!
My apologies if there is a more appropriate place to post this, I didn't know which category best fit.
I have hydronic baseboard heat in three zones, powered by a boiler which also supplies domestic hot. The entire system was new 5 years ago. The problem I describe below is new this year, and has been present since the first night the heat was needed.
One of the zones never fails to work as expected. The other two zones only work if either is active while the first (always working) zone is actively heating. Unfortunately, the zone which always works is the one that should be active the least, leaving the rest of the house cold. (Unless I turn the thermo up to 80 so the other zones will get above 60).
The two trouble zones otherwise function normally when the first zone is active.
I was hoping that this was something that I could fix myself, and that the issue would be familiar to those on this board.
Any information is appreciated. Thank you so much for your time.
Show us a wide picture of your boiler from the front and side please.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1 -
Hello, thanks for the response. I'm out of town for the holiday, but will post a pic when I return this weekend.
Be well,
Justin0
- 50 Industry Classes
