Is this good steam boiler piping?
My guys got called to service it and called in to say we'd better come and take a look.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
It's not only not good piping, it's awful piping. :'(
I can't figure that one out...That's not a picture of JohnNY as we know him.0
It's in process. Proposal sent. Awaiting trigger-pulling.
Do you think I want to be the last company who worked on this boiler as it is?Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes2 -
That's one of the older Crowns that was made by Dunkirk. I bet the installer was fuming that he had to pay for a 2-1/2x2" bushing....
You can't fix stupid!All Steamed Up, Inc.
Consulting0 -
But they got a good price.Retired and loving it.0
I hope that's not an inspection tag on the gas pipe. The wiring looks just as bad0
Dan why is it that they do not have tighter boiler control.My inspectors look for liner and LWCO.I have seen companies that remove the lwco after inspection and plug tee.This is on Long Island.I know you have given your life to the trade but do you ever see in the future maybe boiler licensing and annual inspections like they have in Italy.After all it is the homeowner who in my opinion is being taken advantage of.If money is a problem for them there is organisations that can help.
Thanks for your work and btw HH over the last 2 months has been a great learning curve for a lot of us out their,I am sure you know the threads I am referring to.
Thanks for the kind words. I don't see such legislation coming unless the Long Island politicians can find a way to profit from it personally.jonny88 said:Dan why is it that they do not have tighter boiler control.My inspectors look for liner and LWCO.I have seen companies that remove the lwco after inspection and plug tee.This is on Long Island.I know you have given your life to the trade but do you ever see in the future maybe boiler licensing and annual inspections like they have in Italy.After all it is the homeowner who in my opinion is being taken advantage of.If money is a problem for them there is organisations that can help.
Thanks for your work and btw HH over the last 2 months has been a great learning curve for a lot of us out their,I am sure you know the threads I am referring to.Retired and loving it.1 -
Egads, and coppa pipng. Here's a pic of my boiler install. Done by the best. Gateway PLBG. & HTG. Drop header piping helps heat the house so much faster.0
@JohnNY What kind of dope do you use on your steam piping? I like how it blends in with the black pipe and fittings.wholesalerbill said:Egads, and coppa pipng. Here's a pic of my boiler install. Done by the best. Gateway PLBG. & HTG. Drop header piping helps heat the house so much faster.
My guys tend to use Pro Dope:
http://www.oatey.com/doc/prodope.pdfContact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes1 -
I'll bite. What is so wrong here?0
Copper piping with no swing jointsalheim said:I'll bite. What is so wrong here?
only a single side tapping is used. Both tappings should have been used.
no real header, system risers should not be taken off vertically like that
the equalizer is too high, it should be low enough to drain condensate from the headerSteaming along slowly in Wharton, Morris County, NJ.0 -
In other words, everything!
Here is the manual for that boiler, which was actually made by Dunkirk. Scroll down to the piping diagram to see what we mean:
http://www.dunkirk.com/sites/default/files/3870.pdfAll Steamed Up, Inc.
Consulting0
- 62 Biomass
