Replacement motor
heydan
Member Posts: 2
in Oil Heating
Folks, is there anyone who can help me figure out which replacement motor to get for my oil burner? Here are some photos of the current setup:
You might try Grainger and see if you can find one with exactly the same specs...Br. Jamie, osb
Grainger lists several that might work -
http://www.grainger.com/category/oil-burner-motors/hvac-motors/motors/ecatalog/N-9y9?nls=3&ssf=3&suggestConfigId=2
3PSI gauge0 -
Carlin makes a PSC motor for these burners, part# 98022S.All Steamed Up, Inc.
Consulting2 -
Thanks guys. I think a Carlin 98022 motor will do the job and FW Webb, which is close to me, has it for $64 and will let me return it if it doesn't fit. I'm going to go get it now.0
PSC all the way, just check your coupling length. I find the motor shafts can be slightly longer on PSC motors, Some Beckett anyway, and can cause a problem down the road0
