Burham Gas Boiler Leaking
Purrington
Purrington Member Posts: 1
I have a Burham Gas Boiler.
The name plate says it is a model SP3 SP4 SP5 SP6.
It appears to be leaking although I cannot tell from exactly where. The floor is wet beneath it and to the front right side of it as you face it.
Oddly, the water from it leaking only appears during and shortly after it runs.
When it is off there does not appear to be any leaking?
Does anyone know what the cause might be?
I am on a fixed income and it would be a terribly burden to have to pay for an new boiler.
Thank you.
  • Tim McElwain
    Tim McElwain Member Posts: 4,660
    Have a professional come and look at it as it may only be a fitting leaking and not the entire boiler.
  • jonny88
    jonny88 Member Posts: 1,139
    What's the pressure in boiler
  • kcopp
    kcopp Member Posts: 4,675
    It may be a bad extrol/ diaphragm tank....when it runs the pressure builds and pops the relief valve.
    jonny88
  • Rick2
    Rick2 Member Posts: 4
    Check for flue gas condensation. Maybe it's operating at too low temp.
  • jonny88
    look to the right of the screen,its called advertising.
