Radiator leaking water
greycatlost
Hello,
I have these in-wall radiators in my apartment, three total. 2 work great but the 3rd one leaks water out of the valve(?), the silver piece on the right. It has always done this, but this year it seems to be worse, filling up a bowl with water in less than an hour. My landlords are elderly and do not speak any English, so I'd like to see if I can rectify this myself. Any thoughts or advice are greatly appreciated. Thanks.
That air vent is not a very good one and should probably be replaced with a different brand (Gorton or maid o mist #5?). Put a level on the radiator and make sure there is a little slope towards the opposite end from that air valve.
3PSI gauge0 -
Hi Bob, thanks for the advice, I appreciate it. I put a level on it and it's perfectly plumb(ironic, since everything else in the house is not). Should I shim it up a bit to tilt it away from the vent?
Last question, is it difficult to replace the vent? I am a bit handy, though I haven't done much heating work. Thanks again.0 -
Just looking at that rad, along the floor line, it looks like the rad has settled and is sloped towards the vent (what you are calling a valve) side of the radiator. Pitching it back the other direction as BobC suggests will probably take care of the problem.0
Try a new vent before trying to move the radiator. When the boiler is off and the radiator not steam hot use a wrench to unscrew it from the radiator - make sure you have a replacement vent before taking the old one out.
Wrap some teflon tape around the new vents threads and carefully screw it into the radiator, be careful not to cross thread it.
3PSI gauge0 -
Got it. Thanks Fred, appreciate the input, Will give it a try.
Thanks Bob, I will try a replacement before moving the radiator. Is this something Home Depot would carry, or is it a special order?0
I think Home Depot just sells the same vent you have now. Try Amazon -
http://www.amazon.com/Maid-Steam-Angle-Radiator-Valve/dp/B003DV3AGE/ref=sr_1_1?ie=UTF8&qid=1447808013&sr=8-1&keywords=maid+o+mist+5l
That one comes with an assortment of orifices.
In the meantime try shimming thae radiator as Fred suggested.
3PSI gauge0 -
did you tried to open shut off valve ? air vent, it is not broken anyway. its function to pass air and lock steam in the radiator. there should not be water in the radiator on the air vent level.Gennady Tsakh
Absolute Mechanical Co. Inc.0 -
look for the shut off valve behind the cover. open it all the way and then close it 1/4 turn of the handle.Gennady Tsakh
- 87.8K THE MAIN WALL
- 132 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
