before and after
Charlie from wmass
Member Posts: 4,422
Just an EG35. yes that is a 3" riser on the new boiler.
cell # 413-841-6726
cell # 413-841-6726
3
A thing of beauty, Charlie. Thanks for sharing.Retired and loving it.0
That was alot of work in a small space , really nice.hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
Nice job- this should cut their gas consumption in half.
Looks like the old snowman had a rotary oil burner at one time- I see what looks like the control unit on the floor just to the right of the snowman.All Steamed Up, Inc.
Consulting0 -
Yes I have the control still for the old rotary burner. I will clean it up and maybe make it a jewelry box for the wife. LolCost is what you spend , value is what you get.
cell # 413-841-6726
This is the goal for us all! Thanks for posting.... I miss Jstar's installs, so I'm happy your continuing to post a few.Two-pipe Trane vaporvacuum system; 1466 edr
Very nice job Charlie. I'm curious why you left that ancient gate valve. Also, the old pic is two supply, the new is one ?
Gary0 -
It was a globe valve. It works fine and only serves as a coupling as there are new valves at the automatic feeder. The old had two 2" risers and no equalizer.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
Ok I always assumed each riser led to its own main0
Nope just one main 2" loop.Cost is what you spend , value is what you get.
cell # 413-841-6726
Nice work, what a transformation.0
