Peerless oil boiler temperature gauge reading low
Noluck
Member Posts: 12
in Oil Heating
I have a Peerless oil boiler the aquastat is set at
Low 170 Hi 190
But the Guage on boiler is only reading 125
PSI IS 18
It has a tankless coil I have the hot water running in the shower and the boiler kicks on and runs but shuts down when gauge reads 125
Low 170 Hi 190
PSI IS 18
Yes it is scalding0
Maybe it doesn't work, That's a good guess.....there is a heat compound that is good to use in the wells of the probes...One quick question, what type of system is it high mass or low mass? Is there a boiler bypass installed? Asking because as always a pic should be posted so we can tell what kind if install we are dealing with.?0
Oh how I hate a cliffhanger .....
Hay they all come back...when they need us....0
- 120 Geothermal
