Power venter vs chimney
Geraldo
Member Posts: 16
in Oil Heating
Hi, did a search and did not find much and what I did find was very old. Sorry if I missed something. I have been here since 2001 and just now they are telling me I will need to replace the power venter. Not dead yet and not sure how long before it will be. I have oil heat. There has been years that I needed to replace electronics associated with the venter and sometimes the tube clogged and had to be cleaned but that is it.
I have been calling and asking about a stainless steel chimney. The chimney will be $2500.00 more to install than the power venter and they tell me that in order to keep the warranty I will have to have it inspected every year($95.00) and then cleaned every other year($169 off season $189 in season). Obviously those prices can and will change over time. That is going to cost more over time to maintain the chimney than it has for me to maintain my current power venter, short of complete replacement in a short time. I am hearing power venters are also built better than they were in the past and also more efficient than a chimney. Under the circumstances I don't understand why everyone says to go with the chimney over the power venter. Even if I had to replace the venter every decade it would still take many years to balance out the additional cost of the chimney installation, inspections and cleanings. Maybe I was luckier than most for problems and longevity with the venter.
Maybe I am looking at this wrong. I have had one for many years so I am aware of the noise and fumes when it kicks on with the windows open. I would appreciate opinions if ayone has any experience with current generation power venters, how bad they can be, what I might expect and also would Tjernlund still be the one to get? Thanks.
Nothing has changed with PVs, except for fancier circuit boards. Ash residue will collect on the squirrel wheel-vibration, noise, eventual desentigration. The lesser of the evils is Tjerlund bc the motor is inside. The last thing one needs is a breakdown. At any time, bc you're dead in the water and just about no one carries parts. Chimneys don't break down. Generally
the only thing they have in thier favor is they reduce standby loss from the equipment.
A stainless chimney is king. I disagree with the statement they are more maintenance. Sounds like someone wants to sell you a PV.1 -
I made the statement more maintenance myself because of the extra installation costs and also the yearly cost of inspections and cleanings required of the stainless steel chimney vs what my costs were over the years with the power venter
I asked how often it would have to be cleaned and this was his response.
It is recommended to be inspected on a yearly basis and cleaned every other year. And to maintain the warranty it is recommended to follow these parameters.
I asked what material it was made of and this was his response.
It is an insulated double wall metalbestos all fuel chimney system.
I asked what the warranty was and this was his response.
There is a lifetime warranty and it is made by bestflex0 -
I only burned 735 gallons of oil last year but I do have my system cleaned and tuned every year.0
All fuel insulated is the best of the type. Mounts on exterior. Growing up we had an afterthought boiler venting into one. I don't recall it ever being cleaned. It stayed until removal when my folks went to high-eff LP. We were still able to sell it 25 years later. Those power venters take a beating from oil exhaust.0
I have already arranged to have a stainless steel chimney installed.0
- 87.7K THE MAIN WALL
- 127 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
