two branch tees off main only 5" apart
keyote
Member Posts: 659
in Gas Heating
is there anything wrong with this ? they wont act like monoflo unions in primary secondary and interfere with each other will they? its two 1 1/4 tees spaced 4 3/4 center to center. its just how the risers went up to apts didnt think much about it till rereading primary secondary again and that omg lol
Are they a p/s loop off of the main? I'm not exactly following your discription. If so, the closer together, the better. If it's not p/s, it won't make any difference.Bob Boan
not a loop just two branches thanks0
