If our community has helped you, please consider making a contribution to support this website.  Thanks!
Cutting pipe insulation?
                    SteamedInWharton
                    Member Posts: 62
                    When you have yellow fiberglass with the white outer jacket pipe insulation in 3 foot lengths, what's the easiest way to cut it to length?  I have a miter box and saw, hacksaws, and even a reciprocating saw.  What works best?
                Steaming along slowly in Wharton, Morris County, NJ.
            Same as above. I had a finely serrated knife that was terrible as a kitchen implement, but great for cutting the insulation. I also built a cheap plywood miter box to deal with the size of some of my insulation, I had some 3" piping to insulate with 1 1/2" insulation so the OD was 6 1/2". My regular miter box wasn't that tall.0
            I too use a serrated steak knife.
Nothing else works near as well.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
            Hacksaw for me bros. Kitchen knives mentioned work well too.hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
Ah ha!hvacfreak2 said:Hacksaw for me bros. Kitchen knives mentioned work well too.
But you can't use a hacksaw to cut your steak during break!
 - 87.2K THE MAIN WALL
 - 118 Chimneys & Flues
 - 113 Geothermal
 - 164 Indoor-Air Quality
 - 73 Pipe Deterioration
 - 6.4K Radiant Heating
 - 393 Solar
 - 15.5K Strictly Steam
