Viesmann
lchmb
Member Posts: 2,997
Shout out to Viesmann for taking the time to walk me through the set up on this unit. Had a slight glitch and the gentleman I spoke with walked me through step by step. This is still a work in progress but it's up and running...I would have liked to use the Taco mixing block but I can only install what I'm given..Any suggestions are always appreciated..
Nice workmanship!
Not sure I understand the mixing valves. What model are they?
I guess that's what you meant by installing what they gave you.
Love the hydro separator and the expansion tank detail.
Albert Einstein0 -
Looks great,what kind of gas pipe is that?0
that would be tracpipe. I'd rather have black iron but that does save a few hours..
as far as the mixing valves I would honestly have to go back and look at which model. (I have the box in my truck but it's buried)
Thanks..0
- 50 Industry Classes
