Help identify EDR of Trane steam convector
jason3317
Member Posts: 1
Please help me identify what I have here.
I have recently moved into a house that I believe to use a 2 pipe Trane Vapor steam system. Lucky for me, I am near Frank (Steamhead), and look forward to his visit soon. Although the boiler (Burnham IN-5) is young, there is definitely some work to do in the near boiler piping (it's copper), and I suspect there is some deferred maintenance needed (blow down, skimming, etc). I am mostly interested in i) learning what I have and how to maintain it, ii) greening this system for maximum efficiency - including better venting, 2 stage gas valves, ODR, etc, and iii) making sure it is properly sized to the heat loss of the house.
With that introduction, I need help calculating the EDR of my system, which solely uses Trane 'Extended Surface Heating' tube/fin convectors. I have attached pictures to help. In this example, the convector is 3 steel pipes with a fin area measuring 40"x5.5".
Also, how do you clean these - all of mine appear to have a 30-40 year blanket of dust/crap on the tubes - not helping the heat transfer efficiency!
I look forward to ongoing discussions.
Thanks,
Jason
Thanks,
Jason
Try this- it pays to wander off the Wall:
https://heatinghelp.com/heating-museum/how-to-select-and-install-trane-concealed-heaters/
Looking forward to meeting you and your Trane.
To clean them, set up a vacuum cleaner to blow out rather than suck in, and blow the dust out.All Steamed Up, Inc.
Consulting0
