Inducer has no power to it
rooster5972
Member Posts: 1
in Gas Heating
New smart valve 9541 new fan control 9160 still no power to the inducer checked the pressure switches and the cutout switches also checked hoses for cracks or holes
Is that CB fused? should be a little 5 amp fuse. Does anything happen?
Mike T.
You could have an auxillary limit in the blower compartment open. The system fan would however be running. The system you have powers the inducer from the Smart Valve do you have 120 volts to the valve? If so do you get 120 out of the valve to the inducer?0
