Grundfos wet rotor pumps
Member Posts: 4,581
Have you ever noticed the screws they give you for the covers? Invariable, they strip out before you get the cover secure. We've resorted to having a stock of stainless steel screws just for Grundfos covers.
I looked for a ranting forum, but couldn't find one.
The threads don't strip. The phillips slots strip before you can get the cover anywhere near tight. The screws are cheap pot metal and even with a good phillips screwdriver, the metal just twists off after some resistance.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Hardest screws to bury on a pump electrical cover, bar none.Steve Minnich0
I agree, Alan. I'm not sure it is a true phillips head? New or old, none of the #1 or #2 phillips drivers fit well.The threads don't strip. The phillips slots strip before you can get the cover anywhere near tight. The screws are cheap pot metal and even with a good phillips screwdriver, the metal just twists off after some resistance.
Maybe it's a Torx or something.
I'd rather have a a metric allen or slotted head screw. Zip screws work, kinda.
They have also struggled with wiring connections and terminal strips over the years. They need an installer to design those two components.
I see this all to often, they use some crap hardware to save a few cents. It's one thing if it's a $10 item but they get a lot money for those pumps.
i used to buy hardware for a small production company so I am very familiar with the cost of stainless steel hardware At the production level it would cost 12 to 15 cents to use stainless steel for those three screws.
Shame on them for doing this on a piece of pricey hardware.
3PSI gauge0 -
I see I am not alone in my misery.
I am trying Honeywell pumps on one of my upcoming jobs. They have a label on the junction box where you can write the install date, zone info, etc. Kinda neat I thought.0 -
I suffered as you all have with these screws, then fed up I tried my impact and bam never a tear shed again.0
Taco learned a few things from the HEC-2. The VT-2218's are pretty well thought out.
Grundfos is currently spending some real money re-working the cover attachment on the small MAGNA3's.0 -
Another thing I'd love to see changed with that pump - get rid of the tapped/screwed opening for the electrical fitting and use a typical knockout instead.Steve Minnich0
I hope they re-engineer the speed selector mechanism and lever interface as well. It seems so fragile.
Harvey: Which Honeywell pump are you using?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Armstrong got very close to ideal, on their small ECM. Single cover screw that works, plenty of room inside for wire management, multiple holes for linking pumps.
The spring type terminals are fine for single use, seems if you cycle them a lot they lose interest.
Odd sized holes for the wiring connection? But they include several adapters.
A Unibit fixes the undersized hole if you need 1/2 for flex or liquidtite connectors
I haven't used one yet but have held it in my hand, looked at it and liked it.I hope they re-engineer the speed selector mechanism and lever interface as well. It seems so fragile.
Harvey: Which Honeywell pump are you using?0 -
Deleted, Having connectivity issues. I'll get you a link to the pump yet Alan.0
Is that an ECM pump?0
NadaSWEI said:Is that an ECM pump?
Yeah, I like it!8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
