Air in hot water
Aaron_in_Maine
Member Posts: 315
I have a customer I installed a Heat Flo indirect water heater for a few weeks back. Since the water heater was put in they are getting air out of the hot water faucet. I have put in a couple dozen of these tanks and never had a issue both on town and well water. This one is on a well.
Water quality is the only thing that I can think of. Whatever is in the water may be attacking the anode creating gasses. I would get the water tested and contact the manufacturer.0
Hello: One way to narrow it down is to remove the anode and plug the port. See if the gassing stops. If so, you know it's the anode rather than some well plumbing problem. I wouldn't leave it that way too long.
If you discover it is the anode, you can then go to a less reactive metal, like aluminum/zinc or to a powered anode.
Yours, Larry0 -
Is there an anode in a stainless tank?
I know some installers include a small float style air vent, especially on systems that have iron removal systems that inject air into the water.
It should be a low lead or composite vent, of course.Bob "hot rod" Rohr
There is a anode in the tank. I just found this out today I have put in a lot of these tanks and never had this issue. But this guys water is pretty bad. I am going to have it tested and go from there.
Are anodes new to Heat Flo tanks? I installed one a few years ago and it doesn't have an anode.0
I had air in my system last summer, turned out to be a small hole in the piping going down the well to the submersible pump.
It would be a coincidence, but possible.Bob "hot rod" Rohr
That's what I thought but the air only shows up in the hot water.hot rod said:I had air in my system last summer, turned out to be a small hole in the piping going down the well to the submersible pump.
It would be a coincidence, but possible.There was an error rendering this rich post.
I have this problem with my own system.
It is caused by the water softner reacting with the anode. When the gassing ceases in the morning at the hot tap, I know it is time to replace the anode again
My water is severe and I require three anodes per year.
My tank is propane gas 30 yrs old John woods.
There is a web site that explains hot water tank service.0 -
I think Larry's suggestion is the best one, he has a lot of experience with DHW. He and Suzanne wrote an excellent book on water heaters also.
Also George Lanthiers book The Hot Water Handbook
http://www.waterheaterrescue.comBob "hot rod" Rohr
Living the hydronic dream1
